Human Interface not working for me
Lawrence_Miranda
Has thanked: 1 time
Post by Lawrence_Miranda »
Bought V9 late last night and cannot find a way to input string into the UART. Here is a test program I used that worked great on V8 but not on V9.
UART TEST.fcfx
(11.11 KiB) Downloaded 462 times
Data is pasted into the console Rx queue but is not taken when presented to the UART.
Has thanked: 625 times
Been thanked: 833 times
Re: Human Interface not working for me
Many thanks for letting us know. I beleive I have now found and fixed the problem for you and the fix is now available via the library updates window.
Let us know how you get on.
Lawrence_Miranda
Has thanked: 1 time
Thank you Ben
FITech
Has thanked: 2 times
Been thanked: 2 times
Post by FITech »
Hi Ben,
Sorry to highjack this thread but I was facing the same issue with the PIC16LF1947 but is resolved with the updated libraries.
But now I have this compile error which I troubleshoot is due to the 2nd UART by modifying Lawrence_Miranda's attachment (changing MCU and adding a 2nd UART to the 2D Dashboard).
I have attached it here.
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_2()
   675:	TXSTA2bits.BRGH = 1;
	^ (192) undefined identifier "TXSTA2bits"
	                ^ (196) struct/union required
   679:	RCSTA2 = 0;
	^ (192) undefined identifier "RCSTA2"
   690:	RCSTA2bits.SPEN = 1;
	^ (192) undefined identifier "RCSTA2bits"
   692:	TXSTA2bits.TXEN = 1;
   695:	RCSTA2bits.CREN = 1;
   703:	PIE3bits.RC2IE = 0;
	               ^ (255) not a member of the struct/union ""
	                  ^ (182) illegal conversion between types
int -> volatile union S106
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Uninit_2()
   935:	RCSTA2 = 0;
   936:	TXSTA2 = 0;
	^ (192) undefined identifier "TXSTA2"
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Send_2()
  1022:	while ((PIR3bits.TX2IF) == 0);
	                            ^ (207) simple type required for "=="
  1030:	TXREG2 = nChar;
	^ (192) undefined identifier "TXREG2"
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Receive_2()
  1145:	regcheck = (PIR3bits.RC2IF);
volatile union S62 -> unsigned char
	                           ^ (181) non-scalar types can't be converted to other types
  1280:	regcheck = (RCSTA2bits.FERR);
  1283:	dummy = RCREG2;
	        ^ (192) undefined identifier "RCREG2"
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_UART.c: 1290: too many errors (21)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Previously I was able to compile without errors using both UART on the chip before this library update.
Regards.
FITech
UART TEST.fcfx
(13.18 KiB) Downloaded 490 times
Thanks for letting us know, I've replicated the problem here and solved it for you now via the update system.
FITech
Post by FITech »
Thanks, Ben.
Working fine with the updates.
