Stepper motor component
rzeszurzeszu
Been thanked: 2 times
Post by rzeszurzeszu »
I checked today stepper motor components connected with arduino and drv8825 ( control by step and direction).
Both components seems to have similar behavioir.
diagnosis: The motor squeaks but the shaft is blocked and motor is heating a little bit.
I attached sample of the code. I checked also all the options in the properties, bipolar and all the step types.
thank you for help
stepper test.fcfx
(9.94 KiB) Downloaded 336 times
rzeszurzeszu
Re: Stepper motor component
Delay must be added inside the loop.
Solved
Has thanked: 795 times
Been thanked: 858 times
Hi.
As it's not a bug, I have moved the topic from the bugs section.
Thank you for letting us know your issue has been resolved as it will help others facing the same situation.
