esp32 wrom not programmed
luibra63
Has thanked: 1 time
Been thanked: 4 times
Post by luibra63 »
i upgraded from flowcode8 to flowcode9 last week.
I installed esp32 toolchain as your guide "esp_installation_instruction.pdf", I installed the driver for "ESP32-WROM-32 NodeMCU by AZ-DELIVERY (silabsCP210x)" and I made a simple flash, everything worked correctly. Today I wanted to change the flashing of the led, but it is no longer programmed, I receive the error code "C: \ ProgramData \ MatrixTSL \ FlowcodeV9 \ FCD \ ESP \ Batch \ esp32_prog.bat reported error code 0x1".
I can't program anymore, I uninstalled everything and reinstalled without success.
Can anyone help me?
Thank you
Has thanked: 616 times
Been thanked: 814 times
Re: esp32 wrom not programmed
Please can you attach the .msg.txt file from your project directory and this will show us the error message you are receiving when compiling to target.
luibra63
Has thanked: 1 time
Post by luibra63 »
OK IT'S BIG
Target folder: C:\Users\lbrai\Documents
Source name:   C:\Users\lbrai\Documents\Flowcode1.fcfx
Title:
Description:
Device:        ESP.ESP32.ESP32_WROOM_32
Generated by:  Flowcode v9.2.0.33
Date:          Wednesday, December 08, 2021 00:28:25
Users:         1
Registered to: luibra63 (39177630)
Licence key: 5TR65D
   NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat  "C:\esp-idf\" "Flowcode1" "C:\Users\lbrai\Documents\" esp32s_sdkconfig
C:\Users\lbrai\Documents>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D795899827D9F76D89626FBC8B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EE6FE0BB589D1229A5E37B217FF86DBD72A01B8FBC49BE02BFA3608A0B0CE69F969622A912E6E6A2FB
C:\Users\lbrai\Documents>REM REVISION: 4.0
C:\Users\lbrai\Documents>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
C:\Users\lbrai\Documents>REM DATE: 29\03\2021
C:\Users\lbrai\Documents>REM DIR: FCD\ESP\Batch\esp32_build.bat
Building Flowcode1 ...
Setting IDF_PATH: C:\esp-idf
Adding ESP-IDF tools to PATH...
    C:\esp-idf-tools\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin
    C:\esp-idf-tools\tools\xtensa-esp32s2-elf\esp-2021r1-8.4.0\xtensa-esp32s2-elf\bin
    C:\esp-idf-tools\tools\xtensa-esp32s3-elf\esp-2021r1-8.4.0\xtensa-esp32s3-elf\bin
    C:\esp-idf-tools\tools\riscv32-esp-elf\esp-2021r1-8.4.0\riscv32-esp-elf\bin
    C:\esp-idf-tools\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
    C:\esp-idf-tools\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
    C:\esp-idf-tools\tools\cmake\3.16.4\bin
    C:\esp-idf-tools\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin
    C:\esp-idf-tools\tools\ninja\1.10.2\
    C:\esp-idf-tools\tools\idf-exe\1.0.1\
    C:\esp-idf-tools\tools\ccache\3.7\
    C:\esp-idf-tools\tools\dfu-util\0.9\dfu-util-0.9-win64
    C:\esp-idf-tools\python_env\idf4.3_py3.7_env\Scripts
    C:\esp-idf\tools
Python requirements from C:\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
  idf.py build
[1/8] Performing build step for 'bootloader'
ninja: no work to do.
[2/6] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
In file included from ../main/esp-project.c:40:
C:/esp-idf/components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:110,
                 from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:567,
                 from ../main/esp-project.c:50:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_Float.c:91:6: warning: conflicting types for built-in function '__builtin_isinf_sign' [-Wbuiltin-declaration-mismatch]
 char isinf(float f)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:567,
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:873:13: warning: 'FCI_SCOPY' defined but not used [-Wunused-function]
 static void FCI_SCOPY(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:812:13: warning: 'FCI_SHEAD' defined but not used [-Wunused-function]
 static void FCI_SHEAD(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:792:18: warning: 'FCI_STRMOV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRMOV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:768:18: warning: 'FCI_STRREV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRREV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:698:17: warning: 'FCI_STRING_TO_FLOAT' defined but not used [-Wunused-function]
 static MX_FLOAT FCI_STRING_TO_FLOAT(MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:595:18: warning: 'FCI_NUMBER_TO_HEX' defined but not used [-Wunused-function]
 static MX_STRING FCI_NUMBER_TO_HEX(MX_ULONG Number, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:531:18: warning: 'FCI_FLOAT_TO_STRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:476:17: warning: 'FCI_COMPARE' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_COMPARE(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_UINT8 iNoCase)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:450:13: warning: 'FCI_TOUPPER' defined but not used [-Wunused-function]
 static void FCI_TOUPPER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:424:13: warning: 'FCI_TOLOWER' defined but not used [-Wunused-function]
 static void FCI_TOLOWER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:331:10: warning: 'FCI_TOSTRU32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU32(MX_UINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:297:10: warning: 'FCI_TOSTRU16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU16(MX_UINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:254:10: warning: 'FCI_TOSTRS32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS32(MX_SINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:211:10: warning: 'FCI_TOSTRS16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS16(MX_SINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:182:18: warning: 'FCI_RIGHTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_RIGHTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:159:18: warning: 'FCI_LEFTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_LEFTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:129:18: warning: 'FCI_MIDSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_MIDSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iStart, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:121:18: warning: 'FCI_GETLENGTH' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_GETLENGTH(MX_STRING sStr1, MX_UINT16 iStr1_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:113:17: warning: 'FCI_GETCHAR' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_GETCHAR(MX_STRING sStr1, MX_UINT16 iStr1_len, MX_UINT16 iPos)
[3/6] Linking C static library esp-idf\main\libmain.a
[4/6] Generating ld/esp32.project.ld
[5/6] Linking CXX executable esp-project.elf
[6/6] Generating binary image from built executable
esptool.py v3.1-dev
Merged 2 ELF sections
Generated C:/Users/lbrai/Documents/Flowcode1/build/esp-project.bin
Running ninja in directory c:\users\lbrai\documents\flowcode1\build
Executing "ninja all"...
Project build complete. To flash, run this command:
C:\esp-idf-tools\python_env\idf4.3_py3.7_env\Scripts\python.exe ..\..\..\..\esp-idf\components\esptool_py\esptool\esptool.py -p (PORT) -b 460800 --before default_reset --after hard_reset --chip esp32  write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 build\bootloader\bootloader.bin 0x8000 build\partition_table\partition-table.bin 0x10000 build\esp-project.bin
or run 'idf.py -p (PORT) flash'
Build completed successfully
Using FCD settings for linker
C:\Program Files (x86)\Flowcode v9\data\tools\DoNothing\DoNothing.exe
Using FCD settings for programmer
Launching the programmer...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_prog.bat  "C:\esp-idf\" "Flowcode1" "C:\Users\lbrai\Documents\" COM10 115200
C:\Users\lbrai\Documents>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD51BCA0B0BE9D29A6967C85454D48D34EF6A4CCB7873802B223E4F4A1008A3591A32B46A47AAB2D21848A68B9581D31BC91C05B2A7E3ADB3C4D00059D795899828FA8FC08CAA3178C36704C7C6C9A47105E07F5A3DAE9F727EBE89217067498807D244771FDC991670F5FFC06582E728E4759676487E14245E7CE4E83DB1D25714B4A4F3814D91BF78F4943FF2251F1F8F8986F778F588E992C3050DA273BE4EE1DBDD6E61D775CC70D0E5F8D3FCF5A48FB91B184043A20212EABD4ED9561D2123431AF726C5DC381
C:\Users\lbrai\Documents>REM REVISION: 3.0
C:\Users\lbrai\Documents>REM GUID: 23F1E3A0-C4DC-4746-B4FD-05C4AFBA61E9
C:\Users\lbrai\Documents>REM DATE: 09\03\2021
C:\Users\lbrai\Documents>REM DIR: FCD\ESP\Batch\esp32_prog.bat
Programming Flowcode1 ...
    C:\esp-idf\tools
  idf.py build
[1/4] Performing build step for 'bootloader'
[1/2] cmd.exe /C "cd /D C:\esp-idf\components\esptool_py && C:\esp-idf-tools\tools\cmake\3.16.4\bin\cmake.exe -D IDF_PATH="C:/esp-idf" -D SERIAL_TOOL="C:/esp-idf-tools/python_env/idf4.3_py3.7_env/Scripts/python.exe C:/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="C:/Users/lbrai/Documents/Flowcode1/build" -P C:/esp-idf/components/esptool_py/run_serial_tool.cmake"
esptool.py esp32 -p COM10 -b 115200 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x8000 partition_table/partition-table.bin 0x1000 bootloader/bootloader.bin 0x10000 esp-project.bin
esptool.py v3.1-dev
Serial port COM10
Connecting...
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
CMake Error at run_serial_tool.cmake:50 (message):
  C:/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 failed
FAILED: CMakeFiles/flash
ninja failed with exit code 1
Executing action: flash
Executing "ninja flash"...
Programming Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_prog.bat reported error code 0x1
Autoclose turned off
FINISHED
BEST REGARDS
Has thanked: 724 times
Been thanked: 783 times
Hi.
Next time you go to program, as soon as you see the word Connecting...
Hold the boot button ( nearest the CLK pin) down until you hopefully see the words Writing.
luibra63
Has thanked: 1 time
Post by luibra63 »
woww medlec35
I don't know how to thank you, I've been working on it all today, 1 time out of 10 it worked, but I couldn't understand. thank you very much and good night
Hi, luibra63.
You're welcome.
Thanks for letting us know the solution works for you.
I have just highlighted all of the compiler text and selected the Code display icon </>.
That contains the code within a much smaller area.
For future reference, rather than copy and paste, you select the Attachments tab, Add files, than add the .msg.txt file for your project.
luibra63
Has thanked: 1 time
Post by luibra63 »
thanks Martin.
Perfect, it's the first time I write in this forum, we met in the old forum for problems with FC7 or FC8 and you helped me too. Thanks again
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
After a few hours of testing and checking the compiler messages, I found this topic and this is just what I needed.
Thanks medelec35!
luibra63 & MJU20 I'm glad I can help you both program the Wroom.
ESP32 devices have their quirks, but they are great devices.
I'm glad I could help you both out.
