Adding Byte values inside a ARRAY
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello together,
may someone can help me.
I would like to sum all byte values inside a string or byte array.
Ok I can do this byte to byte.
Example Byte String/ARRAY: Test_byte[5]
sum_byte_int = Test_byte[0] + Test_byte[1] + Test_byte[2]......and so on!!
But I´m looking for a more elegant way to do it.
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 245 times
Been thanked: 257 times
Re: Adding Byte values inside a ARRAY
Hi Dirk
What about this way?
And make sure that the sum is not greater than the maximum value of an integer
dvcam99
Post by dvcam99 »
Super Stefan!!
Works great!!
Many Thnaks
Dirk
