MCP356x still faulty
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
I have provided you with extra hardware free of charge so that you can test it yourself and not program it into the blue.
Then something is programmed.
I find out that it does not work.
then extensions are programmed.
I ask how they are to be used and no answer until today.
I test and find out that it just doesn't work within the specification. Of the 16 possible oversampling ratios, exactly 3 settings run at 2 samples per second. 128, 256,512
The rest do not run.
I would like to have my hardware back next year when your software is running and everyone can use it without problems.
And don't tell me you're not ringing enough bells!
Problems should be dealt with as they arise.
If that doesn't work, then you should expand the team.
sometimes makes sense. SpeedPic32
stay healthy
ADC 9 Test_32.fcfx
(13.99 KiB) Downloaded 622 times
ADC 9 Test_1024.fcfx
(13.99 KiB) Downloaded 545 times
ADC 9 Test_256.fcfx
(13.99 KiB) Downloaded 515 times
