In a user macro, I'm aware any local variable is not retained after the macro exits.
However each time a macro start, can I always guarentee the local values will start with a Value of 0? and is the bahaviour the same between FC and FAD.
or could it be some random value.
If a local value is created with a default value, is this used as the starting value?
Or should I always explicitly set the values at the start of the macro.
Tiying up the tattered edges of my knowledge!
Thanks, J.
Value of Local Variable at start of Macro.
jay_dee
- Has thanked: 99 times
- Been thanked: 68 times
- Has thanked: 147 times
- Been thanked: 815 times
Re: Value of Local Variable at start of Macro.
To be sure - if you need 0 then set an initial value of 0.. I don't think any value is 'guaranteed' otherwise. Local variables are usually allocated on the stack by moving the stack pointer and values will depend on what is in the memory at the time...
- Has thanked: 672 times
- Been thanked: 751 times
mnfisher has a valid point, thanks Martin.
I have tested for uninitialised local on an Uno and it is 0 every time after power-up.
Of course, this can't be guaranteed.
So it is best to initialise in practice.
- Has thanked: 237 times
- Been thanked: 396 times
I think in Flowcode simulation and deployed Flowcode App Developer projects, uninitialised numbers will be zero and uninitialised strings will be empty.
For Flowcode projects downloaded to a chip, uninitialised variables could potentially be anything.
However, I will echo what others have said: it is always good practice to initialise variables if you require or expect them to have a certain value.
- Has thanked: 537 times
- Been thanked: 721 times
A rule of thumb with variables is always write before you read
I think the very strict ESP32 compiler will generate an error if it thinks you are trying to do a read before a write.
