API Sound.LoadWav
Revision as of 16:47, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
Class hierarchy
Sound
LoadWav
STRING Filename
The formatted file to load into memory
BYTE[] Buffer
A buffer to write the wave data to
UINT SampleFormat
This parameter is returned back to the caller
Variable to receive the format of the samples
ULONG Elements
Variable to receive the number of sample elements to play
FLOAT SampleRate
Variable to receive the wave source sample rate
BOOL
  • Add to a calculation icon:
    result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
