Icon Properties
The properties of a command icon defines how it behaves when compiled/assembled and when simulated in Flowcode. As each icon has different properties that the user can edit: see the topic on the particular icon of interest.
To edit an icon's properties, either select the icon and the select the 'Properties' option from the 'Edit' menu (Edit > Properties) or simply double click on the icon in the macro view. The icon's properties can also be displayed by right clicking on the icon to display a context menu and then selecting properties from that menu.
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
Flowcode v9
Flowcode v8
Flowchart icons
Flowchart icons are the commands used in most programming paradigms of Flowcode, i.e. Flowcharts, Code, Blocks and Pseudocode.
Click this link for more information on Editing Icon Properties.
For information on specific icons then see the links below:
Input Icon Properties
Output Icon Properties
Delay Icon Properties
Decision Icon Properties
Switch Icon Properties
Label Icon Properties
Jump Icon Properties
Loop Icon Properties
User Macro Icon Properties
Component Macro Icon Properties
Built-in Functions Icon Properties
Interrupt Icon Properties
Calculation Icon Properties
Code Icon Properties
Comment Icon Properties
Group Icon Properties
State Diagram icons
A different set of command icons are used for Flowcode's State Diagram programming paradigm.
State_Icon_Properties
Exit_State_Icon_Properties
Transition_Icon_Properties
