Output Icon Properties
Output icon send the value or variable to the specified port and/or bits.
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
Flowcode v9
Flowcode v8
Details
Display Name
Port
Select from a list of the ports available on the target microcontroller
Variable or value
Select the name of the variable or a numeric value that you wish to output to the port. Clicking on the down arrow brings up the variables dialog window allowing you to select an existing variable or to create a new one.
Numeric values can be in decimal (unmarked), HEX (preceded by 0x) or binary format (preceded by 0b). e.g. 255, 0xFF, 0b11111111. Users can also use expressions inside the variable or value box, eg "x + 100".
Advanced
By selecting the 'Show advanced options' you can individual pins.
Single Bit
Use this option to write to a single bit of the port.
If a true (non zero) value is sent to the bit the bit is set (turned on), otherwise the bit is cleared (turned off).
Entire Port
Use this option to write the variable or value to the entire port.
Use Masking
When masking is used, it is possible to write to only certain bits of a port. This is useful when some bits of the port are configured as inputs and you wish to leave these bits unchanged.
With masking only the selected bits receive their value, all non selected bits are not affected.
Use chip references
When using target devices that have a mixture of a letter and a number or just a number, for example, on Arduino Uno - A2
If 'Use chip references' is unticked, you can select A2.
If 'Use chip references' is ticked, it will be PORT C2.
Video
See the Output icon video to see how this icon can be used in your Flowcode projects.
