API File.ReadArray
Revision as of 21:14, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Reads an array from the file, returns elements read
Class hierarchy
File
ReadArray
HANDLE FileHandle
The handle of an open file
ARRAY Buffer
An array of some type to read from the file
ULONG Elements
The maximum number of elements to read into the array
The default value for this parameter is: -1
ULONG
Returns elements read
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.ReadArray(filehandle, _arraybuffer, elements)
