Component: Bluetooth (EB024, Generic AT) (Wireless)
Revision as of 13:05, 16 January 2014 by JonnyW (talk | contribs) (XML import)
Author Matrix Ltd.
Version 1.2
Category Wireless
Image Bluetooth (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block.
StringRead
Returns the ASCII value of character idx of the Response string.
BYTE idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
BYTE
SendScript
Sends Script idx
Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent.
Returns 1 for success and 0 for error
BYTE idx
Refers to the Script page to send (1-4).
BYTE
SendCommand
Sends the command buffer.
Returns 1 for success in sending the command.
Returns 0 for errors.
BYTE ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
BYTE SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
BYTE
CreateCommandString
Assigns a string of characters to the Command buffer.
Returns 1 for success in adding the characters to the buffer.
Returns 0 for errors, including Buffer overflow.
<- STRING Data
This parameter may be returned back to the caller
BYTE
StringReceive
Checks for a response string.
Returns the length of the response string if one is present otherwise returns 0.
This macro has no parameters
BYTE
CreateCommand
Adds a single characters to the end of the Command buffer.
BYTE Character
ASCII value or single character,
BYTE
WaitForResponse
Waits for a response message of type response_code for timeout ms.
Returns: 0 for a Response of type response_code
255 (0xFF) for a timeout or invalid response
Response string length for any Response not of type response_code
BYTE response_code
1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
BYTE timeout
The timeout value will need to set to allow sufficient time for the response to arrive.
BYTE
Required to be used whenever the Bluetooth component is used in a program.
Initialises the Bluetooth component ready for use.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
UART Comms Channel
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOWEN.
Determines if flow control is enabled or not
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
UART baud rate, specified by Bluetooth module - normally 9600 is the default
Command Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name CommandBufferSize.
Response Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ResponseBufferSize.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name SCRIPTS.
Controls how many AT scripts are stored into non-volatile memory
Script 1
This property is of type Multiple lines of text and can be referenced with the variable name SCRIPT1.
Data to send for script 0, each command should be terminated with a carriage return
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
UART transmit pin
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
UART receive pin
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name COMport.
Simulation hardware COM port to connect as data end point
