API Panel.Collision.GetMultiAxis
Jump to navigationJump to search<sidebar>API Contents</sidebar> Tests whether an object collides with a position
HANDLE Pos
- A component or position to focus the collision around
FLOAT X
- Local or world-space X to return
 - This parameter is returned back to the caller
FLOAT Y
- Local or world-space Y to return
FLOAT Z
- Local or world-space Z to return
HANDLE TargetSpace
- The target space to calculate X,Y,Z in
Returns true if the operation is a success, else false
 - Add to a calculation icon:
result = ::Panel.Collision.GetMultiAxis(pos, return_x, return_y, return_z, targetspace)
Detecting Collisions
Simple example showing how to detect for collisions between objects on the panel. An object moves back and forth between two fixed objects. Each time the moving object hits a static object it will change it's direction.
