API Sound.QueueEx
<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
HANDLE Sounds
- The handle of the sound object to queue to
BYTE[] Data
- The array to play data from
ULONG ByteOffset
- The byte-offset in the array to start at
UINT SampleFormat
- Format of the samples
Typical values for this parameter:
ULONG Elements
- The number of sample elements to play
FLOAT RateMul
- A multiplier to the sounds sample rate
- The default value for this parameter is: 1
- Add to a calculation icon:
result = ::Sound.QueueEx(sounds, _arraydata, byteoffset, ::Sound.Fmt_Signed8, elements, ratemul)
