API Panel.Position.Math.GetDistance
Revision as of 21:21, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Gets the distance between two positions
===Class hierarchy===Panel
Position
Math
GetDistance
HANDLE Pos0
Start of line to calculate distance from
HANDLE Pos1
End of line to calculate distance to
HANDLE Relative
Optional position to calculate the distance in
FLOAT
Returns the distance between two positions
  • Declare a variable 'result' of type FLOAT
  • Add to a calculation icon:
    result = ::Panel.Position.Math.GetDistance(pos0, pos1, relative)
