Component: One Wire (Comms: Interface)
Revision as of 09:20, 28 July 2016 by BenR (talk | contribs)
Version 1.3 (Release)
Category Comms: Interface
Image One Wire component
Low level routines for controlling or interacting with a standard one wire interface.
Single Device
Here is an example program to read a single DS18S20+ one wire temperature sensor device using a 16F1937 device. The DS18S20+ is connected to pin C0 and to display the temperature there is a LCD connected to PortB.
Single One Wire Demo
Multiple Devices
Here is an example program to read multiple DS18S20+ one wire temperature sensor devices connected to pin A0 and display the temperature of the selected sensor onto a LCD connected to PortD. Switches connected to pins C0 and C1 allow the currently active sensor to be set.
Multiple One Wire Demo
DS1820_StartConversion
DS1820 device specific function
Commands all sensors to start a temperature conversion
This macro has no parameters
BYTE
ReceiveByte
BYTE
TransmitByte
Transmit a byte to the one wire bus a bit at a time
BYTE Command
GetPadByte
Returns a byte from the last read scratchpad at position index. The index byte can go from 0 - 8 to reference the 9 individual scratchpad bytes.
BYTE Index
Select which pad byte to use 0-8
BYTE
BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse.
Returns 0 if a presense pulse was detected
Returns 1 no device was detected
BYTE
ScanBus
Scans the one wire bus to detect all devices
BYTE
GetDeviceCount
Returns the number of detected devices
BYTE
GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
BYTE device
BYTE octet
BYTE
DS1820_ReadScratchpad
Reads the scratchpad of the currently selected device
BYTE
ReadDevice
Reads the temperature of the device at location count in the id array
BYTE count
BYTE
DS1820_GetTemp
Returns the two byte value of the temperature sensor
UINT
Simulation macro reference
One Wire Pin
This property is of type Single digital pin and can be referenced with the variable name oo_pin.
I/O pin used to host one wire bus.
CRC Enabled
This property is of type True or false and can be referenced with the variable name crc_en.
Sets the CRC bit based error detection on or off. (cyclic redundancy check)
Label to draw on the GUI object for identification
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Lists all the current injector components available on the user's panel
