Component: SPI Master (Comms: Interface)
Revision as of 09:13, 28 July 2016 by BenR (talk | contribs)
Version 1.3 (Release)
Category Comms: Interface
Image SPI Master component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available.
Overview
The SPI bus is a high speed communications bus which is usually best suited for talking between devices situated on the same circuit board. Due to the high frequency digital nature of the bus care should be taken to keep tracks as short as possible and as far away as possible from other sources of noise. A typical SPI bus consists of four signals, chip select, data out, data in and clock. The SPI bus usually consists of a single master device and then one or more slave devices.
As the data out and data in signals are subjective in terms of who is sending and receiving the data there are alternate names to help clarify the connection.
Data out (SDO) is also known as MOSI which stands for Master Out Slave In.
Data in (SDI) is also known as MISO which stands for Master In Slave Out.
Each SPI transaction consists of a byte made up of 8 clock cycles allowing the 8-bits of the byte to be transferred.
Chip Select CS / Slave Select SS
Each device connected to the SPI bus connects in parallel to the main three SPI pins: data out, data in and clock. The fourth pin the CS pin must be unique for every SPI device present on the bus allowing only one device to be addressed at any one time. As every slave device on the SPI bus requires a individual CS signal from the SPI Master a good way of adding more devices without consuming more of the pins of the SPI master is to use things like 3 to 8 pin multiplexer ICs. The CS signal activates the slave device when pulled low and disables the slave device when pulled high.
Adding a pull up resistor of around 10K - 100K between the CS signal and VCC allows the SPI slave device to be disabled whenever the Microcontroller is not ready to perform the functionality of the SPI master e.g. during reprogramming or when the device is held in reset.
Three Wire SPI
Three wire SPI is a version of SPI where the master can send data to the slave device but cannot read any data back for example a DAC or graphical LCD.
Four Wire SPI
Four wire SPI is the complete version of SPI where the master can sent data to the device and receive data back from the device. A single SPI operation simultaneously transfers a byte from the master to the slave via the MOSI signal and also a byte from the slave to the master via the MISO signal. Normally only one of these bytes is meaningful so it's down to the protocol of the slave device as to how to perform writes and reads.
SendString
Sends a string of bytes to the SPI bus
<- STRING Str
This parameter may be returned back to the caller
GetString
Attempts to read a string of bytes from the SPI bus.
BYTE NumBytes
BYTE Ch
STRING
SendChar
General purpose SPI send byte macro
BYTE Char
GetChar
General purpose SPI get byte macro
This macro has no parameters
BYTE
UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Activates the SPI peripheral and claims control over the I/O pins.
Simulation macro reference
GetConsoleHandle
HANDLE
SPI Channel
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
SPI peripher onboard the target microcontroller to use.
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name PR_SCALE.
Rate by which the master oscillator is reduced before clocking the SPI peripheral.
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name CKP.
The polarity of the clock signal
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name CKE.
The phase of the clock signal related to the data signal.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SMP.
Point in the clock period to sample the data signal.
MOSI (SDO)
This property is of type Single digital pin and can be referenced with the variable name MOSI.
Data Out Pin - Micro Out Serial In
MISO (SDI)
This property is of type Single digital pin and can be referenced with the variable name MISO.
Data In Pin - Micro In Serial Out
CLK
This property is of type Single digital pin and can be referenced with the variable name CLK.
Clock Pin
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Injector component to allow the data in simulation to be passed to something meaningful.
