API Panel.Position.MoveAlong
Revision as of 22:08, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Moves the object by the given offset relative to its parent along an axis
Class hierarchy
Panel
Position
MoveAlong
HANDLE Handle
HANDLE Axis
A position or component representing the X,Y,Z axis to move in
FLOAT X
Local coordinate X to increment by
FLOAT Y
Local coordinate Y to increment by
FLOAT Z
Local coordinate Z to increment by
  • Add to a calculation icon:
    ::Panel.Position.MoveAlong(handle, axis, x, y, z)
