API File.Buffer.ReadByte
Revision as of 22:11, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Reads a single byte from the input stream, -1 if empty
Class hierarchy
File
Buffer
ReadByte
HANDLE FileHandle
The handle of an open file
ULONG Timeout
A number of milliseconds to wait for the byte to be available
INT
  • Declare a variable 'result' of type INT
  • Add to a calculation icon:
    result = ::File.Buffer.ReadByte(filehandle, timeout)
