API Panel.Position.MoveBy
Revision as of 01:52, 12 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Moves the object by the given offset relative to its parent
Class hierarchy
Panel
Position
MoveBy
HANDLE Handle
FLOAT X
Local coordinate X to increment by
FLOAT Y
Local coordinate Y to increment by
FLOAT Z
Local coordinate Z to increment by
  • Add to a calculation icon:
    ::Panel.Position.MoveBy(handle, x, y, z)
