Component: FCD helper (Matrix Tools)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Matrix Tools |
FCD helper component
A helper control to query the current Flowcode definition XML file.
| GetStrListItem | |
| Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added | |
| Index | |
| Name | |
| GetIntListItem | |
| Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added | |
| Index | |
| Name | |
| SetRange | |
| Sets the min-max range to draw on the dial Used for setting the needle | |
| [[File:]] - | Start |
| [[File:]] - | End |
| [[File:]] - | Return |
| SetLabel | |
| Sets the label to draw in the center of the dial | |
| Hi | |
| Lo | |
| Label to draw at the bottom | |
| SetPivotPos | |
| Sets the position of the object the lever rotates around | |
| [[File:]] - | PositionHandle |
| A handle to the position of the depressed location | |
| SetLatching | |
| Sets whether the button is depressed when the mouse is released | |
| [[File:]] - | Enabled |
| Unregister | |
| Removes the object to the list if present | |
| [[File:]] - | Target |
| SetMovementFor | |
| Sets the movement in units or PI/16 steps for the button | |
| [[File:]] - | Move |
| Movement to set to, default 4 | |
| Properties | |
| Connections | |
| Simulations |
