API Sound
<sidebar>API contents</sidebar> Audio streaming interface
Functions provided for this class
| Play | Plays a formatted file sound, returns true if the sound played OK |
| LoadWav | Queues a sound for playing, with the format provided |
| Create | Creates a sound object that data can be played through |
| SetVolume | Sets the volume of playbacks for this sound |
| GetVolume | Gets the volume of playbacks for this sound in the range 0 to 1 |
| GetBits | Gets the number of bits per sample for the sound |
| GetRate | Gets the current sample rate for the sound |
| SetRate | Sets the current sample rate for the sound - this will stop the playing sound |
| Queue | Queues a sound for playing |
| QueueEx | Queues a sound for playing, with the format provided |
| Flush | Stops all playing and queued sounds |
| GetPending | Gets the number of sample blocks queued or playing for the sound |
Constants provided for this class
| Type | Name | Value | Value |
| LONG | Fmt_Signed8 | 4 | Source data is in the range -128 to 127 |
| LONG | Fmt_Unsigned8 | 5 | Source data is in the range 0 to 255 |
| LONG | Fmt_Signed16 | 8 | Source data is in the range -32768 to 32767 |
| LONG | Fmt_Unsigned16 | 9 | Source data is in the range 0 to 65535 |
| LONG | Fmt_Signed32 | 16 | Source data is a signed 32-bit value |
| LONG | Fmt_Unsigned32 | 17 | Source data is an unsigned 32-bit value |
| LONG | Fmt_Float32 | 18 | Source data is a 32-bit float from 0 to 1 |
| LONG | Fmt_Float64 | 34 | Source data is a 64-bit float from 0 to 1 |
| LONG | Fmt_Mono | 256 | Set this flag to set a single source element per sample |
| LONG | Fmt_Stereo | 512 | Set this flag to two source elements per sample |
See also
