Component: Airplane Landing Gear (Scenarios)
| Version | 1.0 (Release) |
| Category | Scenarios |
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
There is a scenario detailed here to go with this component.
This component does not contain any downloadable macros
Simulation macro reference
FrontDoors
Will allow the front doors to open.
- BYTE Direction
- Drops the door down or close them. 0 = Close 1 = Open
FrontDoorCloseSwitch
Test to see if the Front door will touch the collision switch by its original position. If it does, will return true. and stop movement.
Assigned variable of a Bool is recommended
LandingGearDownSwitch
Test to see if the Landing Gear will touch the collision switch by its final position. If it does, will return true. and stop movement.
RearDoorLocks
Will unlock or lock the rear doors
- BYTE OpenOrClose
- Open =1 Close =0
LandingGearUpSwitch
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement.
FrontDoorOpenSwitch
Test to see if the Back door will touch the collision switch by its final position. If it does, will return true. and stop movement.
FrontDoorLocks
Will lock or unlock the front doors depending on the number given to the paremeter.
- BYTE OpenOrClose
- Open =1 Close=0
LandingGear
Retracts and drops the landing gear.
- BYTE Direction
- Drop the wheel down or retracts them. 0 = Retracts 1 = Drop
RearDoorCloseSwitch
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement.
RearDoors
Will allow the rear door to open
- BYTE Direction
- Drop the door down or close them. 0 = Close 1 = Open
RearDoorOpenSwitch
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement.
This component does not contain any properties
