Component: Digital Temperature (EBM004) (EBM Modules)
Revision as of 09:39, 22 October 2018 by BenR (talk | contribs)
Version 2.0 (Release)
Category EBM Modules
Image Digital Temperature (EBM004) component
A digital temperature sensor based around the LM75B chip.
This example simply reads the value from the digital temperature sensor and outputs the value to an LCD as a temperature in degrees C.
EBM004 Example
ReadInt
Read double byte data from register at address
BYTE address
INT
ReadFloat
Reads the temperature value as a float
This macro has no parameters
FLOAT
WriteByte
BYTE address
BYTE data
BYTE
WriteInt
BYTE address
UINT data
BYTE
ReadByte
Read a single byte at a specific address from the chip's internal memory.
BYTE address
BYTE
Uninit
Uninitialise and release resources
Initialise to default of 11 bit resolution
BYTE
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Simulation Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
A text label to help you identify the component on the panel.
Min. Temp.
This property is of type Floating point and can be referenced with the variable name min_temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
This property is of type Floating point and can be referenced with the variable name max_temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
This property is of type Unsigned integer and can be referenced with the variable name scale_divisions.
Number of numbered divisions shown on the thermometer scale.
I2C Data
This property is of type Fixed list of ints and can be referenced with the variable name number_base.
Set whether the I2C data is displayed as decimal or hexadecimal numbers.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
