Component: IO Expander (BL0155) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
 IO Expander (BL0155) component
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
Before you can start reading or writing data to the different registers or ports, you need to use a macro to initialise the IO expander. There are component macros in flowcode 8 which allow you to write a value to a register on the expander, to write a value to an individual port or even to an individual pin on a port. You can also read values from all these places using component macros as well.
You also need to ensure that all pins in flowcode are connected to the equivalent ones on your E-blocks 2 upstream board for it to work when you compile it to the chip.
ReadPort
Reads a value to one of the ports with a mask.
Configures the masked bits to be inputs before reading the input value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Mask
- Allows port bits to be modified without effecting other bits, 255 = write full port.
ConfigureInversion
Configures the pin inversion for the two ports.
Disabled on all pins by default.
- BYTE PortA
- Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
- Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
Reads a single port pin from one of the ports.
Configures the pins to be an input before reading the input value.
Returns 0 or 1 corresponding to the value on the port pin.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Pin
- Port pin to read. Range: 0-7
WritePortPin
Writes a single port pin on one of the ports.
Configures the pins to be an output before writing the input value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Pin
- BYTE Value
- Value to output on the selected pin. Range: 0-1
WritePort
Writes a value to one of the ports with a mask.
Configures the masked bits to be outputs before writing the output value.
- BYTE Port
- 0=PortA, 1=PortB
- BYTE Mask
- BYTE Value
- Value to write. Range 0-255
ConfigurePullups
Configures the pullups for the two ports.
- BYTE PortA
- Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
- Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE Address
- Register address to write to. Range: 0-15
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE Address
- BYTE Value
- Value to write. Range: 0-255
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
