API File.Open
<sidebar>API contents</sidebar> Opens the existing file as a standard stream
STRING Filename
- A textual filename to open
BOOL Read
- Set to enable read access
BOOL Write
- Set to enable write access
BOOL Monitor
- Set to enable monitoring of the file
- Add to a calculation icon:
result = ::File.Open("filename", true, false, true)
