Component: Hall Effect (EBM011) (EBM Modules)
| Category | EBM Modules |
Hall Effect component
The board has a Hall Effect sensor (SL353) that gives a digital output in the presence of a magnetic field (in the region of 60 Gauss) from a permanent magnet or electromagnet, either North or South pole.
Sample program using the EBM011 - Hall Effect sensor
Reads the sensor and displays output on LED D7.
|   | ReadSensor |
| Macro to read the Hall Effect Sensor. Returns a boolean value. 0 = Object sense, 1 = No sense | |
| [[File:]] - | Return |
|   | SampleDevice |
| Reads the Axis data from the device. Returns 0 if successful | |
|  - BYTE | Return |
|   | ReadRegister |
| Read the data byte at the given address of the device | |
|  - BYTE | Reg |
| address of the register to be read | |
|  - BYTE | Return |
|   | Initialise |
| Initialise the component. Returns 0 if successful | |
|  - BYTE | Return |
|   | Initialise |
| Set up the thermocouple sensor ready for use. | |
|  - VOID | Return |
|   | Initialise |
| Initialise the sensor configuration as set by the component properties | |
|  - VOID | Return |
|   | Initialise |
| Stes up the I2C bus and initialises the termperature sensor ready for use. | |
|  - VOID | Return |
|   | SimSetGyro |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
|  - VOID | Return |
|   | UpdateAccelerometerData |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
|  - BYTE | Return |
|   | SimSetCompass |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
|  - VOID | Return |
|   | Initialise |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
|  - BYTE | Return |
|   | IOSetOutputPin |
|  - BYTE | Pin |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
|  - VOID | Return |
|   | UARTReceive |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | OneWireScanBus |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | SPIInitialise |
|  - BYTE | Channel |
|  - VOID | Return |
|   | OneWireReceiveByte |
| Receives a byte from the one wire bus a bit at a time | |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | I2CSend |
|  - BYTE | Channel |
|  - BYTE | DataOut |
|   | UARTSend |
|  - BYTE | Channel |
|  - BYTE | Data |
|  - VOID | Return |
|   | OneWireGetDeviceCount |
| Returns the number of devices found by the last ScanBus operation. | |
|  - BYTE | Channel |
|  - BYTE | Return |
|   | PWMSetPrescaler |
| Sets the prescaler for the PWM output | |
|  - BYTE | Channel |
| Range: 0 - 11 | |
|  - BYTE | Prescaler |
|  - BYTE | Period |
|  - VOID | Return |
|   | PWMEnable |
| Enable a PWM output | |
|  - BYTE | Channel |
| Range: 0-11 | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Channel |
|   | Connections |
|   | Simulations |
