API Panel.Graphics.DrawText
Revision as of 21:16, 12 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Draws a line of text texture
Class hierarchy
Panel
Graphics
DrawText
FLOAT X
Initial horizontal position of text (depends on Align)
FLOAT Y
Initial vertical position of text (depends on Align)
STRING Text
The text to draw, may be multiple lines
BYTE Align
The text alignment
Typical values for this parameter:
Type Name Description
LONG Align_TopLeft Text is left aligned and drawn below the Y coordinate
LONG Align_TopCenter Text is center aligned and drawn below the Y coordinate
LONG Align_TopRight Text is right aligned and drawn below the Y coordinate
LONG Align_CenterLeft Text is left aligned and vertically centered
LONG Align_Center Text is horizontally aligned and vertically centered
LONG Align_CenterRight Text is right aligned and vertically centered
LONG Align_BottomLeft Text is left aligned and drawn above the Y coordinate
LONG Align_BottomCenter Text is center aligned drawn above the Y coordinate
LONG Align_BottomRight Text is right aligned drawn above the Y coordinate
  • Add to a calculation icon:
    ::Panel.Graphics.DrawText(x, y, "text", ::Panel.Graphics.Align_TopLeft)
