API Sound.QueueEx
Revision as of 21:17, 12 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
Class hierarchy
Sound
QueueEx
HANDLE Sounds
The handle of the sound object to queue to
BYTE[] Data
The array to play data from
ULONG ByteOffset
The byte-offset in the array to start at
UINT SampleFormat
Format of the samples
Typical values for this parameter:
Type Name Description
LONG Fmt_Signed8 Source data is in the range -128 to 127
LONG Fmt_Unsigned8 Source data is in the range 0 to 255
LONG Fmt_Signed16 Source data is in the range -32768 to 32767
LONG Fmt_Unsigned16 Source data is in the range 0 to 65535
LONG Fmt_Signed32 Source data is a signed 32-bit value
LONG Fmt_Unsigned32 Source data is an unsigned 32-bit value
LONG Fmt_Float32 Source data is a 32-bit float from 0 to 1
LONG Fmt_Float64 Source data is a 64-bit float from 0 to 1
LONG Fmt_Mono Set this flag to set a single source element per sample
LONG Fmt_Stereo Set this flag to two source elements per sample
ULONG Elements
The number of sample elements to play
FLOAT RateMul
A multiplier to the sounds sample rate
The default value for this parameter is: 1
BOOL
  • Add to a calculation icon:
    result = ::Sound.QueueEx(sounds, _arraydata, byteoffset, ::Sound.Fmt_Signed8, elements, ratemul)
