Component: Image (2D Shapes)
Revision as of 10:34, 17 November 2021 by Wiki bot (talk | contribs)
Author Steve Tandy
Category 2D Shapes
Image component
A basic image component for the 2d panel.
GetValue
Reads Named property Value.
- STRING Name
- STRING Return
Slave_Init
Initialise the Slave
Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Uninit
Uninitialise the Master
Master_Byte
Sends and receives a data byte
- BYTE DataOut
GetConsoleHandle
Returns a handle to the console used by this component
[[File:]] - Return
Slave_TxByte
Sets the data to be transmitted to the SPI master.
- BYTE Data
Slave_RxByte
Returns the data received from the SPI Master
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
Master_Init
Initialise the Master
GetList
returns Named property list
- STRING Name
- STRING Return
Filename
Vertical Alignment
Horizontal Alignment
Simulations
