Component: Bluetooth (ESP32 SPP) (Wireless)
| Category | Wireless |
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
| ReceiveByte | |
| Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured | |
| Timeout | |
| Number of ms to wait for incoming data | |
| SendString | |
| Sends a string to the Bluetooth serial connection | |
| Data | |
| Data Array to send | |
| CheckConnectionStatus | |
| Checks to see if the Bluetooth device is connected. Returns 1 if connected. | |
| [[File:]] - | Return |
| ReceiveCount | |
| Collects the number of bytes currently stored in the receive buffer. | |
| SendArray | |
| Sends a byte to the Bluetooth serial connection | |
| Data | |
| NumBytes | |
| Number of bytes to send | |
| SendByte | |
| Data | |
| ReceiveString | |
| MaxBytes | |
| Max number of bytes to try and read within the time | |
| Timeout | |
| Starts up the Bluetooth communications SPP service. | |
| Delay | |
| Software UART Bit Delay | |
| SetValue | |
| set Value of Named property | |
| Name | |
| Value | |
| Uninit | |
| Un-initialize the UART and release the resources | |
| GetList | |
| Gets Named property List | |
| Name | |
| GetList | |
| returns Named property list | |
| Name | |
