Component: Simulation External Input (Runtime Tools)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Runtime Tools
Simulation External Input component
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. Allows things like switch presses or external square waves to be used with the simulation.
Control_Pulse
Controls if the toggle input is enabled or disabled allowing you to stop and start the waveform.
- BYTE State
0=Disabled, 1=Enabled
Get_Pulse_Count
Reads the number of pulses remaining in the current run. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
- ULONG Return
Set_Space
Overrides the component property setting allowing for a variable frequency input or adjustable Space timings.
- UINT Delay
Delay between transitiions in milliseconds.
Set_Pulse_Count
Overrides the number of pulses. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode.
- ULONG PulseCount
Number of pulses to output
Set_Frequency
Allows the frequency to be changed on the fly
[[File:]] - Frequency
Set_Mark
Overrides the component property setting allowing for a variable frequency input or adjustable Mark timings.
- UINT Delay
SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
- BYTE State
A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
GetConsoleHandle
[[File:]] - Return
SendByteArray
Sends an array of bytes to the COM port.
- BYTE Data
Data byte array to send
- UINT Length
Number of bytes to send
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
[[File:]] - MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
Max time in ms to wait in between bytes
[[File:]] - IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
[[File:]] - Return
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
[[File:]] - Number
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG Number
- BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
[[File:]] - Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
- BYTE State
OpenPort
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE Timeout
[[File:]] - Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG Return
SetProp
- STRING PropName
- ULONG PropVal
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG Value
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] - Value
GetProp
- STRING PropName
- STRING Return
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE Data
- UINT MaxLength
Max number of bytes to try and read
- UINT Timeout
Time to wait for incoming data in milliseconds
ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT Timeout
- UINT MaxLength
- STRING Return
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING PropName
- STRING Return
Pin
Pin to toggle - connected to the external waveform on the target hardware.
Startup Mode
Controls if the pulses start when the simulation is started or when the simulation Control_Pulse macro is called.
Mode
Frequency (Hz)
Frequency to try and acheive.
Period Delay (ms)
Delay in milliseconds for a whole period of 0 and 1.
Mark Delay (ms)
Delay in milliseconds to wait to toggle the pin. Note that Windows can only acheive timings of 10ms or more.
Space Delay (ms)
Pulse Count
Number of pulses to output. 0 = Run forever. > 0 = Output the selected number of pulses
Simulations
