Component: Speech (RealSpeak) (Indicators)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Indicators |
Speech (RealSpeak) component
Advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine. Available in simulation only.
| GetTag | |
| Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long. | |
| Data | |
| IsKnownID | |
| Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory. | |
| [[File:]] - | Return |
| Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored. | |
| OpenPort | |
| Opens the currently selected COM port, allowing data to be sent and received. | |
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| SendByteArray | |
| Sends an array of bytes to the COM port. | |
| Data | |
| Data byte array to send | |
| Length | |
| Number of bytes to send | |
| SendFloat | |
| Sends out a floating point number as an ASCII String from the UART interface. | |
| [[File:]] - | Number |
| SetFlowControl | |
| Allows the Flowcontrol signals to be enabled or disabled. | |
| State | |
| A value of 0 disables flow control, 1 or above willl enable flow control. | |
| OpenPort | |
| SetProp | |
| PropName | |
| PropVal | |
| SendBinary32Bit | |
| Sends out a 32-bit binary value split across four bytes. | |
| Value | |
| [[File:]] - | MSBfirst |
| 0=Least significant byte first, 1=Most significant byte first | |
| GetProp | |
| PropName | |
| GetProp | |
| PropName | |
| Properties | |
| Voice | |
| RealSpeak selected voice - Download and install RealSpeak voices for more options. | |
| Rate | |
| Voice speech rate - Default 1 - Range (0-100) | |
| Connections | |
| Simulations | |
