Component: Barometer (MS5637) (Environmental)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Category Environmental
Barometer component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
ReadPressureFloat
Reads the pressure as a floating point value in Bars. Resultion sets the return bit value and conversion time. Calls the ReadPressureRaw function and then converts to a meaningful value.
- BYTE Resolution
Range 0-5
[[File:]] - Return
Reset
Resets the device
ReadTemperatureFloat
- BYTE Resolution
Range 0-5
[[File:]] - Return
ReadPressureRaw
Reads the pressure as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.11mBar / 1=0.062mBar / 2=0.039mBar 3=0.028mBar / 4=0.021mBar / 5=0.016mBar
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
Reads the temperature as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.012°C / 1=0.009°C / 2=0.006°C 3=0.004°C / 4=0.003°C / 5=0.002°C
- BYTE Resolution
Range 0-5
[[File:]] - Return
ReadPROM
Reads a single 16-bit value from the PROM calibration data.
- BYTE Address
Range 0-6
Stes up the I2C bus and initialises the termperature sensor ready for use.
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Injector
Simulations
Simulate Comms
