Component: GLCD (SSD1306) SPI (SSD1306) (Graphical Monochrome)
Revision as of 11:09, 17 November 2021 by Wiki bot (talk | contribs)
Version 0.1
Category Graphical Monochrome
GLCD (SSD1306) SPI component
Graphical display component based on the SPI version of the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin forcing the data to be written a byte at a time.
The following files provide examples of how to use this component:
Digilent - Basic IO Shield
This template allows users to quickly and simply get up and running with their hardware.
The default microcontroller for this template board is the 32bit PIC32MX320F128H found
on the Uno32 hardware.
It features;
4x push-switch, 4x slide switch
8x LEDS, 1x Potentiometer
1x OLED Screen
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SendCommand
- BYTE Command
[[File:]] - Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
ControlDisplay
Allows the display to be switched on and off
- BYTE Control
0=Off, 1=On
SendData
- BYTE Byte
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ControlContrast
Sets the display contrast from 0 to 255.
- BYTE Contrast
Range 0 - 255, Default 207
Uninitialise
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Interlaced
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Data (SDA)
Serial Clock (SCL)
Reset pin connection
DataCommand Pin (DC)
Data / Command select pin
VBAT Enable
VDD Enable
VDD Enable Pin
Reset
The LCD Reset pin
Simulations
