Component: DAC (Internal) (Analog Output)
Revision as of 13:28, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Analog Output
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
SetOutput
Sets the output voltage of the DAC
- UINT DAC_Value
The value to output to the DAC
GetValue
Gets the Name property value
- STRING Name
The name of the property
- STRING Return
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
SetValue
Sets the Value for the named property
- STRING Name
Name of property to update
- STRING Value
The new value for the property
GetList
- STRING Name
- STRING Return
DAC Channel number
DAC Output Pin
DAC Output Pin
Vref Option
Vref Voltage
Control Bits
Resolution
Voltage Resolution
Simulations
