Component: API (ECIO40P) (API Slave Devices)
| Version | 4.0 |
API (ECIO40P) component
Connects to an ECIO40P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
The App Developer (ECIO40P) component allows an ECIO40P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO40P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ECIO40P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO40P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
| App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 |
| Device Port Pin | A0 | A1 | A2 | A3 | A4 | A5 | B0 | B1 | B2 | B3 | B4 | B5 | B6 | B7 | C0 | C1 | C2 | C6 | C7 | D0 | D1 | D2 | D3 | D4 | D5 | D6 | D7 | E0 | E1 | E2 |
| App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Device Port Pin | A0 | A1 | A2 | A3 | A5 | E0 | E1 | E2 | B2 | B3 | B1 | B4 | B0 |
| App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | UART RX | UART TX | PWM 0 | PWM 1 |
| Device Port Pin | B0 | B1 | C7 | B0 | B1 | C7 | C6 | C2 | C1 |
Direct Slave Access
Here is a simple demo to switch on and off digital pin 29 (the LED pin).
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
ECIO App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
ECIO App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
ECIO App Developer Slave UART Demo
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
| IOGetInputPin | |
| Pin | |
| Range: 0-29 | |
| ADCSample8 | |
| Reads the voltage present on an Alanog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-12 | |
| UARTInitialise | |
| Channel | |
| UARTCheckRX | |
| Channel | |
| RegisterWrite | |
| Writes to one of the registers on-board the device | |
| RegisterAddress | |
| The address of the register | |
| Data | |
| The data value to assign to the register | |
| RegisterRead | |
| Read one of the registers on-board the device | |
| RegisterAddress | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ADCSetReferenceVoltage | |
| Specified the reference setting for ADC reads. | |
| RefType | |
| 0=VDD 1= VREF+ (AN3) | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-1 | |
| Duty | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-12 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| State | |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
| Initialise the comms to the ECIO40P device, ready for commands to be sent. | |
