Component: SRF (WirelessThings) (SRF) (Wireless)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Wireless |
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
SendString | |
Send a string of data using the SRF Module | |
- STRING | Data |
- VOID | Return |
Wake | |
Wake the SRF module. Includes a 10ms delay to allow radio to wake. | |
- VOID | Return |
SendChar | |
- INT | Char |
- VOID | Return |
Sleep | |
Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending) | |
- VOID | Return |
SRFInitialise | |
Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping. | |
- VOID | Return |
ReceiveString | |
- BYTE | Timeout |
- BYTE | NumBytes |
- STRING | Return |
ReceiveChar | |
- BYTE | Timeout |
- INT | Return |
