Component: DC Motor ()
| Author | Matrix Ltd. |
| Version | 1.2 |
| Category |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels.
Motors
| Coast | |
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
| Break | |
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
| Disable | |
| Disable the motor output | |
| Forwards | |
| Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property. | |
| Duty | |
| Sets the motor power for PWM or H-Bridge outputs | |
| Enable | |
| Enables the motor output | |
| Reverse | |
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
| Duty | |
