Component: FTDI (FT800) (FT800) (Misc)
Revision as of 16:19, 7 January 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Misc
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
COMMSA
IncrementCommandOffset
Adds commandSize to the currentOffset. Checks for 4K ring-buffer offset roll-over
- UINT currentOffset
graphics processor command list pointer
- BYTE commandSize
number of bytes to increment the offset
MemRead16
Reads a single unsigned int from the FT800 internal address space
- ULONG Address
MemRead8
Reads a single data byte from the FT800 internal address space
- ULONG Address
MemRead32
Reads a single unsigned long from the FT800 internal address space
- ULONG Address
- ULONG Return
MemWrite16
Writes a unsigned int value to the FT800 internal address space
- ULONG Address
- UINT Data
MemWrite8
Writes a byte value to the FT800 internal address space
- ULONG Address
- BYTE Data
CommandWrite
Sends FT800 command
- BYTE Command
MemWrite32
Writes a unsigned long value to the FT800 internal address space
- ULONG Address
- ULONG Data
System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
Power Pin
CS Pin
Width
Active width of LCD display
Height
Active height of LCD display
HCycle
Total number of clocks per line
HOffset
Start of active line
HSync0
Start of horizontal sync pulse
HSync1
End of horizontal sync pulse
VCycle
Total number of lines per screen
VOffset
Start of active screen
VSync0
Start of vertical sync pulse
VSync1
End of vertical sync pulse
PixelClock
Pixel Clock
Swizzle
Define RGB output pins
Clock Polarity
Define active edge of PCLK
Simulations
API
