| Author
Matrix Ltd
| Version
2.0
| Category
Audio
Heelight Sensor (Grove 101020312) component
Heelight Sensor is a smart voice sensor that can recognize up tp 500 digital voice commands. It was originally used on the Heelight – a smart colorful bulb that can be controlled by digital sound waves. Allows you to realize smart control in your own projects. Compatible with Heelight smart phone apps and other Heelight controllers.
SENSORS
ReadData
| Reads data received from the listen macro.
- BYTE
Index
| Data Byte Received Range: 0-3
- BYTE
ListenForCommand
| Listens for a Heelight command with timeout. Returns 1 if a command received. Returns 0 if no command was received.
- BYTE
Timeout
| 0=Don't Wait, 1-254=MilliSec Delay, 255=Wait Forever
- BYTE
| Sets up the UART peripheral ready to receive messages from the Heelight sensor.
| UART Channel selector
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
Simulations
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
