API Sound.LoadWav
<sidebar>API contents</sidebar> Loads a wave file into memory, providing the values needed to play it
STRING Filename
- The formatted file to load into memory
BYTE[] Buffer
- A buffer to write the wave data to
UINT SampleFormat
- Variable to receive the format of the samples
- This parameter is returned back to the caller
ULONG Elements
- Variable to receive the number of sample elements to play
FLOAT SampleRate
- Variable to receive the wave source sample rate
BOOL Returns true if the operation is a success, else false
- Add to a calculation icon:
result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
