Component: Hall Effect Analog (Magnetic)
Revision as of 15:36, 17 December 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Magnetic
Hall Effect Analog component
Simple analogue hall effect triggered by the proximity of another object.
SetTarget
Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
- HANDLE Target
The object to test for collision with.
ReadProximityByte
Get the current proximity reading as a digital value from 0 to 255. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
ReadProximityFloat
Get the current proximity as an analogue value from 0.0 to 1.0. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
- FLOAT Return
ReadProximityInt
Get the current proximity as a digital value, 10 bit or 12 bit based on your ADC capabilities. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Analog Pin
Polarity
The 'Polarity' property will affect whether the signal increases of decreases as the proximity increases. Rising - Increases signal as proximity increases Falling - Decreases signal as proximity increases
Simulations
Magnet Object
Select an object from the panel to act as the magnet that triggers the reed switch.
Range
Distance within which the sensor begins to be activated. NB) This is measured between the centre of the proximity sensor and the centre of the target object.
Timer Interval (ms)
Time in milliseconds between testing for proximity. Small time = Greater CPU load Large time = More like to miss activation if it is very brief.
