Component: Potentiometer (Panel) ()
Revision as of 15:39, 14 February 2022 by MartinW (talk | contribs) (Examples)
Version 1.4
Category
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
BASICIO
LCD Example
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Simulations
Start Angle
Sweep Angle
