Component: Potentiometer (Slider) ()
Revision as of 15:48, 14 February 2022 by MartinW (talk | contribs) (Examples)
Version 1.3
Category
Potentiometer (Slider) component
Analogue slider with plastic cap and 100mm travel. Cap and marker colour can be changed in component properties.
BASICIO
Potentiometer Example
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Simulations
Tang Color
Colour of the moving part of the slider.
Marker Color
Colour of the marker line across the slider tang.
Body Color
Specifies the color of the slider body
