API Panel.Position.Animate
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Blends positions from two sources to a destination over time
Class hierarchy
Panel
Position
Animate
HANDLE Dest
HANDLE Start
The initial position of the animation
HANDLE End
The final position of the animation
UINT Millisecs
Time to take to perform the animation
The default value for this parameter is: 1000
  • Add to a calculation icon:
    ::Panel.Position.Animate(dest, start, end, millisecs)
