API Panel.Position.StopAnimate
Revision as of 22:58, 14 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Stops all animations started by this component
Class hierarchy
Panel
Position
StopAnimate
This function has no parameters
This call stops all animations invoked by the caller of the routine by jumping each animation to the end of its sequence.
A component can not stop another components animations, and this can not be used to exit leaving an animation partially complete. For this level of control the Morph call should be used in a timer.
  • Add to a calculation icon:
    ::Panel.Position.StopAnimate()
