Component: Switch (Controls)
| Author | Steve Tandy |
| Category | Controls |
Switch component
A 2d switch component.
FREE
Switch
The polarity setting within the switch properties determines how the relevant bit of the input variable responds when a switch changes state. This applies only when using switch functions and not when using input command icons.
- Active High Polarity: When the switch is closed, the voltage on the pin transitions from 0V to the positive supply voltage (either 3.3V or 5V, depending on the microcontroller). As a result, the corresponding bit in the input variable changes from 0 to 1. A pull-down resistor is required for the input pin to ensure it stays at 0V when the switch is open.
- Active Low Polarity: When the switch is closed, the voltage on the pin transitions from the positive supply voltage to 0V, and again, the relevant bit of the input variable changes from 0 to 1. A pull-up resistor is required for the input pin to ensure it stays at the positive supply voltage when the switch is open.
(5V / 11K) * 10K = 4.54545V
| GetState | |
| Reads the state of the switch (true = on, false = off) | |
| SetState | |
| Sets the switch to be on or off. | |
| bState | |
| The new state of the switch (true=on, false=off) | |
| Properties | |
| State | |
| Style | |
| Type | |
| On Label | |
| Off Label | |
| Background Colour | |
| Connections | |
| Simulations | |
