API File.WriteArray
Revision as of 13:16, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Writes an array to the file
Class hierarchy
File
WriteArray
HANDLE FileHandle
The handle of a file to write to
ARRAY Data
An array of some type to write to the file
ULONG Elements
Maximum number of array elements to write
The default value for this parameter is: -1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.WriteArray(filehandle, _arraydata, elements)
