Component: Switch Array (Push) (Switches)
Author | MatrixTSL |
Version | 1.0 |
Category | Switches |
Switch Array (Push) component
An array of up to eight slide switches. In embedded mode each switch is connected to a single pin of the specified port.
Please click here for the component source code: FC_Comp_Source_Switch_Array_Push_2dgi.fcfx
Here is an example Flowcode program to read the values of a switch array.
Switch Array
(5V / 11K) * 10K = 4.54545V
ReadState |
Read the state of the switch at the given index. | |
Index |
The switch to read the status of. | |
Return |
WaitUntilHigh |
Pause the program until the switch at the given index is turned on. | |
Index |
Index of the switch to wait for. | |
Return |
ReadAll |
Reads all of the switches at once, returning a byte containing one bit per switch. | |
Return |
WaitUntilLow |
Index |
Return |
