API Component.Delete
Jump to navigationJump to search| Delete | |
| Deletes an existing object, removing it from the panel | |
| Target | |
| The object to delete | |
This deletes a component.
Root components and component definitions may not be deleted. All other components may be deleted.
The components memory may not be freed immediately. The system will queue deleted components and erase the memory when the component is not referenced. Therefore a component may delete itself in its own event macro and safely complete processing.
- Add to a calculation icon:
result = ::Component.Delete(target)
